LED Reverse lights, Flashers, DRL's
Phantomx55
Slow
New Jersey
I recently converted most of my lights to LED's and I was wondering if anyone has also converted there 3157 bulbs to LED as well.
I was looking into getting either the 3157 18 LED or 45 LED high powered tower bulbs at http://www.superbrightleds.com/cgi-...ispPage&Page2Disp=/tail-brake-turn.html#a3156
The 18 LED one tells me not to use it for DRL's but doesn't mention the same thing with the 45 LED ones.
If anyone has used these or something similar, please don't hesitate to give your $.02
Edit: Also it says for turn signals to look at load resistors and flashers which are below it on the page. Would they be required?
Physh1
From what I read you can either get load resistors or flashers to make the turn signals work properly (ie no hyberblink)...either choice will work. Using a load resistor on each DRL will also keep them from blowing out...voltage spikes from startup...
Cameron
