LED Tail Light Re-Wiring so Both Sets stay on (How To)
l2yan
This is just a quick write up to make LED tails light up on the top as well as bottom when your parking lights are on. This should work with all Tail Lights but I'm not of the wiring in OBS and NNBS. I did this on an NBS. I initially wanted them to all blink and all light up brighter when brakes are applied but will work on that later. In order to do that I may need to change out the actual harness or install resistors. Not something I was up to doing today =)
Here is a picture of the style lights that I have. Only the bottom stayed on with parking lights and the top Blinked with blinkers. Now all of them stay on with parking lights. The top still only blinks and the bottom still only brightens with brakes:
After Removing the Tails you will see this, or something like it. I had to switch positioning of sockets when installing these. Blinker Top - Reverse Middle - Brake/Running Bottom:
So what you want to do is cut the blue wire and the black wire coming from your harness for the blinker. Be sure to cut them off not splice into them.
Then you want to take the end coming from the socket and connect the blue wire to the brown (running light) wire. Then take the Black wire and connect it to the Blue wire coming from the body (The one you just cut). This will leave you with one open ended black wire coming from the body that I just looped back into the plastic covering. Connect these however you see fit. I used a T-Tap for the Blue to Brown and just stripped wire and connected the black to the blue.
After that test to make sure and your done. Quick and easy. Mine is kinda messy I will probably go back and clean it up once I actually figure out how to make them blink and brake in unison.
Here is the end Result:
Thanks for Looking!
Also if anyone knows the part number to the lock cover for the spare tire please let me know!
chip
Tampa
Awesome post! I will definitely be doing this! Thanks Ryan!
Administrator
awesome info! :waytogo:
2005yukonxl
with those particular little bitty round LED tails, u need all teh light u can squeeze out. i cant imagine driving around at night (or in the daytime) with those, especially with only half of them lit up. good to see you doing something to try to improve on them...
l2yan
l2yan
Thanks for the write up, I will be doing this soon. Here is a link for the bumper cover.
http://www.lmctruck.com/icatalog/ce/search.aspx?searchItem=rear%20bumper
Thanks man exactly what I need
---------- Post added at 05:15 PM ---------- Previous post was at 05:14 PM ----------
Ya I am looking into new Tails mainly cuz I'm bored of them lol. Would like something a bit more IN YOUR FACE when i stop =)
2005yukonxl
get some of the clean LEDs like the most of us are running...they coem in smoke so u can keep with your theme, or tint them slightly (although i cringe i just suggested that) and they are still bright enough not to invite a rear ender. much cleaner than those dodge durango looking round ones too
l2yan
l2yan
I think I'm going to get those. If anyone has some Smoked ones from X3 they want to get rid of let me know!
http://cgi.ebay.com/ebaymotors/ws/e...75381&ssPageName=STRK:MEWAX:IT#ht_7373wt_1165
Venom One
Tried this today and it kept blowing the fuse. I was real careful in following the directions, wires, etc.....so much for that.
jeffyrc
Bow Tie For Life
SoCal
ok u cought me. im not gonna lie. i have no clue what it means. i just wanted to put something there so i could refer to it later
cpranger22
