LEDSs headlights package
Dooba
I'm close to pulling the trigger on this setup but I'm worried that it'll void my warranty.
If i replace the halogens with LEDs on my 16 SLT, will my warranty be partially/fully voided?
Angel87
AngelXL
AngelXL
Yukon is the one the left...lighting up can and hand truck.
So far so good and like i said for $40 bucks. I ordered another set for back up and install is so easy that even if one or 2 fail. I got the other ones in the trunk... pull over and do a swap.
No biggy.
AngelXL
AngelXL
I don't stress that!
Are you going to tell them if you go for an oil change? If you go for a related issue... just swap them out.
I'm 47 and i been in the car audio & security business seen I was 17. You know how many times I heard that...
In 1998 i bought a Lincoln Navigator brand new. Did everything you can think of for back then. Remote starter with alarm, tvs, booming system, ect..
One day some wires melted from relays and other stuff outside in the engine compartment. I was so worried with all the s...t that i had done.
Sevice and mechanic guy told me don't worry. All your extra connections are right and it got nothing to do with the problem.
ONLY time we have a problem is when we see some Hack jobs.
Angel87
Anyone with aftermarket fogs on Tahoes have leds and what kind?? Bulbs size with the aftermarket fogs are H3 and it seems like Cree doesn't have that bulb size?
Broham
So Cal
Usually the only time aftermarket parts void your warranty is if it is a direct cause to whatever goes wrong.
shelton_yukon17
I just bought the suggested led's for the fog lights. Fortunately I already have HID headlights. Just wanted them to match. My question is, do you need a can-bus fix for the lights to work properly? I hope not. On my 2014 jeep grand cherokee you needed them otherwise the lights would malfunction.
AngelXL
AngelXL
I didn't use the can-bus and so far everything is good. I just got an email from onstar but nothing on the car.
I went with just the bulb for the fog lights. From Xenon.com
