gmartin1215
- Joined
- Nov 9, 2012
- Posts
- 245
- Reaction score
- 105
I have a 2009 Tahoe LT with 4WD with 140K miles. This vehicle also has a 2" ReadyLift leveling kit (spacer on top of coil-over).
I also posted in the Engine and Drivetrain forum, but I am looking for more opinions and this forum is more about suspensions.
I have been getting a popping or thumping sound coming from the driver-side front area that usually happens when the wheels are turned to go right. I don't get this all the time, but I have heard happen when I am backing out of my sloped driveway and turning the truck to get on the street. I also have heard it pop when turning right into a parking space. I also have heard it doing this sound backing out of my garage after it has set, and I maybe changed the steering a little. It's not constant, it will just make this popping sound and not do it again until next time.
I did jack up the front end and checked for any play in the wheel by grabbing at 12 and 6, and 3 and 9 and I did not get any so I think it's not my ball joints. I checked the sway bar links on both sides and they are both tight and the links are not broken. I also checked the left front tie rod end to see if there is any play by grabbing and trying to see if it would move and I did not have any, nor did I see any sign of wear.
I did have the left CV axel replaced because the old one had a torn boot, so I am beginning to suspect that it's the problem. The part I replaced the old one with is an ACDelco 22789359 which is the same as my old part. I did struggle some putting the hub nut from the old axel on to this new one - the threads were tighter and had a hard time getting the nut to turn. I did not cross thread because I was able to back it off and see if there was any thread damage and then retested the not on the old axel to verify I did not trash the nut. I did get the not to set, but it was a struggle with my impact wrench. However, I do seem to recall getting a similar sound before I replaced the axel, but it's been a while I may be recalling something else.
I am half tempted to put the old CV axel back on to see if the problem goes away, but as you know, that is a lot of work.
With the sway bar links totally disconnected and then a test drive, I am still getting that popping sound. So it's definitely not the sway bar links.
Got a video of the popping sound. You can hear at about 0:47, 1:47, and 2:30
In the video, I am not hearing anything from the CV axel while it's turning, so I am suspecting that it is not guilty of the popping sound. But, I am not sure.
I lifted the Tahoe by the left lower control arm and did the 12 to 6 wobble on the tire. There is a little play going on, and you can hear a thumping sound when the tire is moved in the 12 to 6. I got another video of the upper ball joint with some help from a helper.
I also did the pry bar under the tire with a helper, and I could not really see a lot of play. I will try to get a video later.
Right now, I am stuck trying to find out the cause of this sound and don't want to go down the route of replacing parts until I am more positive about the root cause.
Given what I have described, would you suspect it's the ball joints that are giving off this sound? If not, then what do you think might be the cause and where I should do further inspection?
