Leveling kit vs body lift
Shaw520
I'd like to hear all opinions ..I think the costs are pretty comparable.. I know that a body lift will not affect suspension angles,.. Id like to hear the pros and cons along with the mechanical effort involved in both.
Ty
73impala
Margate, FL
Imo biggest BL I would go with is an 1.5 because I don't like seeing the frame stick so low. I assume we are talking about the tahoe in your avatar, leveling kit isn't hard with the nbs. Remove torsion adjuster bolt bang the torsion bars out of the keys/lca slide the leveling key in and put the torsion bar back in. Then either new shocks or shock extender.
Shaw520
Shaw520
Yes, certainly simple enough,..but limited to 2.5". Never the less, i will most likely go that route, and ad a BL later if i desire more.
CamReynolds
w
what id do if you have the funds, get torsion keys to level out the front but dont mess with the rear, then do a 1.5 inch body lift. this will keep your angles pretty good but it will be basically a 3.5 inch lift and will be inexspensive
Shaw520
Shaw520
w
This is most likely the approach I will take,.. except I will ad air bags to the real coils,.. I have bags in my other trucks and it allows for some versatility in height and payload capacities. I'm hoping to stuff 305's under this setup,.. with a little trimming im sure !
CamReynolds
I
I have 285 and could easily put 295 with only torsion keys. 305 shouldn't be a problem. 33s will look good too
trav02nj
