adp1326
i installed the truxx 2.5" front and 1.5" rear and am running 305/55-20 nittos. had to trim front slightly. i paid $135.00 at tire rack.
emann, your truck will have the Cali stance with that size kit. That is the front will be higher than the rear. With 2.5" front you should go with at least a 1" rear. I would recommend a 1.5" rear if you tow or load the truck frequently.
Hey!
Looking to lift the 09 Tahoe. Is there an advantage/disadvantage to the Rough Country type of lift/leveling system for the front versus aluminum spacer placed above the front shocks? The Rough Country looks easier to install, but also appears to be make of a plastic. Any opinions/thoughts... experiences??
Thanks for any help!
Andrew
