leveling Tahoe side to side and dropping rear more
jeff laing
Hi I’m new to the site.. I have a 15 tahoe LTZ I just dropped over the weekend. I used the norcal 2-4.5 kit but being 4x4 the front does not drop as much as the 2wd so I also used a 1” strut relocator. The driver side sits 1/2 lower then the passenger and didn’t know if there was a solution to get them level from the gas tank being on the driver side. I have the rear air ride links as short as I can get them and I have not heard the compressor kick so that’s good, the driver rear height is not to bad (could be a little lower ) pass side to high. So I might take out the rear air and front mag shocks and replace with beltech.
And input would be appreciated
LF- 32 3/4. LR 34 1/4
RF- 33 1/4. RR- 34 3/4
Excuse the front end I had a mis hap and wanted to do the suspension before it went to the paint booth and put my Wheels on
2C654C67-6B48-4474-A044-C98642545940.jpeg 8D5FE015-3CBF-48EB-B685-DD6B1006390D.jpeg 33B4F39F-EDB0-477D-9473-96189630942A.jpeg
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
2 options in rear
1) cut top of spring on higher side
or
2) pass side endlinks cut and make 1/2 inch shorter
on front you can get energy suspension endlinks and
1) make pass side endlink shorter which in turn will pull that side down
or
2) do my strut mod which you mill the snap ring lower
or
3) remove 1 ring on the right side spacer on the strut relocator on pass side
Mreedini
