Ok thank you. This is a separate question but would a tire that's 275/60R20 fit on a 12" wide wheel?New shocks or shock extenders in the front
How wide of a tire would you recommend?It will "fit" but its going to be stretched. Not something I'd do since I don't think stretching a tire is that smart, nor does it look good, but that's my .02. Plenty of people do it and get away with it no problem.
Forgot to mention that tire is 275/35 meaning the sidewall is 35% of 275mm, while the tire you picked is 275/60, meaning it's 60% of 275mm tall, which is why it's a 33" tall tire, so it may not look as stretched at the one I posted, but will still stretch a little bit.I'd stick to 10" wide if it was me. But if you really want a 12" wide rim it would work, since it's only an inch wider than the tire. You're only really gonna start to see major stretching on like a 14" wide rim with that tire size. The picture is of a 275 wide tire on a 12" wide rim, so not too bad, and if you want a stretched look then I think you'd be alright with it.
Thanks for the help, I tried looking for 20x10s but for some reason a wheel and tore package for those are more expensive than the one I found for 20x12s and I like wheels with a little bit of stretching so I'll go with those.Forgot to mention that tire is 275/35 meaning the sidewall is 35% of 275mm, while the tire you picked is 275/60, meaning it's 60% of 275mm tall, which is why it's a 33" tall tire, so it may not look as stretched at the one I posted, but will still stretch a little bit.
I will definitely post a pic when I get them on there but the site I'm ordering them from has a 4-8 week back order on the setup I want so it will take a little whileNo problem man. Hope everything works out, cant wait to see them when they get mounted.
