Lift Kit for 2WD Z71
A
atothez
So how much rear lift do you get with the rough country springs - is it a full 6 inches? I am only planning on the 3 inch spindles for now - guess I could do keys later for more front lift
---------- Post added at 11:50 AM ---------- Previous post was at 11:49 AM ----------
Oh and your Tahoe is awesome
Z-56 Hoe
What do I do????
Houston
I first did spindles and pro-Comp keys. ( the keys are installed but not cranked!)
In the rear I did coil spring spacers and jeep Sway bar end links And a new adjustable Pan Hard bar. But I was sitting a little over 2" higher in the front so. I went to a friends body shop and he called Rough country and said he had a lifted Tahoe that had been wrecked and he need the rear section of lift kit. It rides and handles great.
Z-56 Hoe
What do I do????
Houston
The pic above is before I swapped to the 6" R.C. Kit in the rear image.jpg this picture is of the front ground clearance
Z-56 Hoe
What do I do????
Houston
And this is the T - bars not cranked but the Pro Comp keys installed
Brice25
