Lift kit options
NJTahoe
Looking to setup my truck to look like this Tahoe. Anyone have any suggestions on which lift kit to look into and what offset wheels?
Thanks
AquinoSteven
Key and Spacer Guru
Clinton, NJ
YES!!!! another lifted NJ tahoe. Welcome to the club. It looks like a 6" lift. At that point its all down to personal preference. Fabtech and Procomp make good lifts.
CREETO
new orleans
i would look at rancho or superlift for the suspension lift kits... heard mixed reviews on fabtech, and don't know about pro-comp. you'll need 5.5 inch backspacing for your rims. keep in mind you will have a change in trackwidth between front and rear after lift kit install unless you get fabtech kit which requires a narrower tire. if the trackwidth difference is an issue, like it was with me, you can buy spacers for the rear, or different backspaced rims for front and rear (but will have rotation issues later). i am completely happy with the superlift l got and i'm sure if gonzo is around he can attest to the rancho. picture.jpg[/IMG]
Tahoe03mm
Puyallup, WA
From what I read 4.5 is the min on backspacing. Depends on kit though and the manufacturers have the specs on their websites
Max
Mile High
Denver
There are two different types of lift systems for these trucks, a knuckle kit or a full control arm drop kit. The knuckle kits (rancho, fabtech, zone, cognito, superlift FIT, RCX) are easier to install but will increase the front track width (distance between the front tires) where the full drop kit (pro comp, superlift bracket, ) will stay at the factory location. I've had really good luck with the 6" pro comp kit if you wanna go a bit higher I'd recommend the cognito kit as they're worth the extra money for a solid system with the pitman/idler reinforcements.
SloZ71Hoe
East Texas
I just got done puttin my 6" RCX lift on it... i love it. i also have key's up front and a 1.5" spacer out back. This is my tahoe on 20's and 35's. These wheels have about a -12mm offset...
These wheels are just temp for right now. Im ordering new ones after my income taxes come in. lol
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
SloZ that looks damn good, i think you should keep those wheels and get different tires
---------- Post added at 08:16 PM ---------- Previous post was at 08:14 PM ----------
ahh now i want a bagged tahoe and i want a lifted one......frig
SloZ71Hoe
East Texas
haha, well i want a little more offset on the wheels... and the tires will get replaced after the wheels. Hell i got those tires for 300 bucks and they are 75% or so. lol
NE5683
