Lift problems
I put a 3 inch block and leveling kit on my98 tahoe and when I went to get it aligned the front sway bar hits the upper control arm right on the end links. Also when I take off from a stop sign something jerks and squeaks please help I'm 16
bowtiefreak
No Quarter
Near Philly
can you put a picture up? Instant solution is decrank, maybe longer sway bar end links. Get that picture and we'll get you straightened out
Donnie Yukonie
Yates Caretaker
Create a Photo bucket account and then either send them to your account via mobile phone or upload from your computer , When your ready to post them click on the IMG code and copy and paste it , If you have any questions how to do this let me know and I can PM you so we don't clog up your thread .
Jerky Arm Ape
North East Louisiana
Mine is lifted the same way, have both of those problems.
When you crank your front end up, the a-arms have less distance away from each other
In the sway bar end link area.
I bought my truck this way and when I rebuilt the front suspension and steering I flipped the end links so the threaded end faces downward.
As for the rear, I assume its a number of things causing the jerk/squeek.
One, your leaf spring had a lot more torque-twist on take off caused by moving the axle 3" away from the leaf.
Two, you loose about 1.5" of spline coverage on your transfer case yolk.
Add those two together and you aquire some problems.
Something you haven't looked at yet is the upper balljoint bolts (if it has had them replaced before, if not it won't be long).
The angle causes them to dig into the steering knuckle and this eats the bolt away.
I noticed this on mine searching for slack.
If you want three inches, despite the pros and cons they have, a body lift is a better way to do it.
Upon my next rebuild I will go back to stock suspension and a body lift, have some used oem u-bolts aleady just missing two washers :(
Body lift is more labor intensive than what you have done, but it saves lots of $$$ in both the short and long run.
Ejwr
