Lifted Yukon XL - Suburban - ESV pics
jvoisel
New Orleans, La
Thanks!
I was torn on what to do, I had the lift, a 2/3 drop, the rims, and 2 sets of tires so I couldn't decide if I should go up or down. I'm happy with how it came out, dont think I would have liked it lowered.
Felix, where are you in Louisiana?
Administrator
Ah,,,gotcha :waytogo: I like the Nissan rims better :High 5: now that you've had both which do you prefer?
cttandy
The suburban wasn't setup for big tires like my pickup is. It road rough, tracked badly, couldn't use over drive, and ate gas like it was wholesale priced. The kevlar tires on 18 inch wheels weigh around 150 lbs a corner at least. Stopping distance, well, it would never lock the tires up. It just kept rolling
With the nissan wheels, the burb is very precise and controled. It doesn't track or wonder at all. Braking is pretty good, and they are much lighter when I am servicing the burb.
Now my pickup is setup for big tires. Even though it is geared high, it has a very heavily built trans. The brakes are beefed up. It all works well when setup right. My pickup is currently on 245/70r16s it chirps the tires when it shifts and will throw you through the windshield when you stop.
WhiskeyTangoFoxtrot
Mine.
What size rims and tires are on your rig? Also, is it lifted or just leveled?
Thanks
SUBURBIAN
All Chevy
This is my daily driver. I'm 2nd owner. Bought in 2010 with ~150K miles, now about 223K. Good southern truck spent its life in MS, so no rust. I've done quite a bit to it. Rebuilt entire front end down to gearbox, fuel pump/tank, MC/booster, pretty much everything else you could consider a "wear part"; PS pump, radiator, wiper motor, etc., etc., etc.. Built 355 with MPFI, 600 horse built 4L60E, S10 converter, Magnaflow duals, 6" RCX lift, Bilstein 5100's, 4.56 Yukon gears/duragrip posi, 18" DC2's now wrapped in 34" Nitto G2's. Anzo low brow halos with HIR's, GMT800 tow mirrors, nice aftermarket HU/speakers, I don't think I'll ever be done building on this thing, from the little things to the $$ items.
SPIS
