Lifter noise
K9Gunner
I have a little lifter noise on start up. It goes away when up to temp. Gonna try my hand at pulling the valve covers and carburetor cleaning down the rods. Wish me luck. It’s been a great vehicle. 276k miles and counting.
Are you sure it's not a broken exhaust manifold bolt? Sounds just like a lifter tick.
K9Gunner
K9Gunner
I’ve checked both hoping it was one of the two.
dwinters14
This made me realize my truck has tick too... I'm gonna put some Marvel Mystery Oil in her and bring up my next oil change by half and hope that helps. I noticed some sludge in the oil pan when I replaced my gasket so I'm gonna assume the engine is dirty.
K9Gunner
K9Gunner
Well I finally found the fix to my lifter noise. It got progressively worse and I remembered someone on here saying try a new oil pump. So that’s what I did and there has not been any lifter noise in the last two weeks amd it has been cold, for NC anyway. I am very happy with the results
PNWYukon
Olympia, WA
Good news. Was it OEM? Did you install it?
K9Gunner
K9Gunner
Honestly no clue on brand. My mechanic did the work. But I will find out what brand
89Suburban
Bull in the china shop
SE PA
What did it cost you and do you have 4WD?
K9Gunner
K9Gunner
I had several things down. High pressure oil pump installed. Water pump replaced. Belt replaced. Lower control arm replaced. And safety inspection. Total was $1390 I will look at receipt and get you exact on HPOP.
davemitchell117
