Hello all,
About 6 months and 10,000 miles ago I put in a rebuilt 5.3 in my 2001 Tahoe. She’s at 275k right now and running great. However, a couple weeks ago I took it in for an oil change and when I started it up after, I got a slight lifter tick. I thought it was odd but just assumed it was due to the cold and it being new oil. Now, every time I start the vehicle I will get a significant lifter tick while driving until the oil fully heats up. The coolant temperature gauge will always hit 200 degrees and then shortly after the ticking goes away. I tried changing the oil again but that has not changed anything. I also put in an oil additive as well and that has not changed anything. When I idle to let the car warm up I do not hear any ticking but once I give it gas I can hear it. Any ideas what this could be caused by? As it’s a new engine and the oil was clean after changing it, I don’t think it could be a gunked up lifter. I also do not push the engine while it’s ticking as I do not want to damage the new engine. Thank you all for your thoughts.
