lifting help
ccvikes11
I am a poor college student with a vision, if you look at my pictures you can see that the top of my truck looks alright, but my only problem is it need to be bigger. how can i lift my truck cheap. im open to all suggestions. and i thank you in advance for your contributions.
bowtiefreak
No Quarter
Near Philly
3" body lift, crank the stock keys about 2" and add a 1-2" block out back. Do the work your self and this should cost no more than a couple hundred bucks....less the tires
ccvikes11
ccvikes11
thanks man one more question where are the keys and how do i crank them
BattelWagun
Chi-Town USA
They are two bolts located in a crossmember near the midpoint of the truck. You should see two long steel rods going into them (torsion bars). All you need to do is tighten those two bolts, 1 per side. Just make sure you keep track of how much you crank them and make sure the truck is level. You'll also probably need an alignment too after. Putting the blocks in isn't hard at all, pretty straightforward.
ccvikes11
ccvikes11
thank you for your input, where should i buy the blocks and what kind should i get.
Donnie Yukonie
Yates Caretaker
hate to go off the topic but where did you get that roof rack an how much im lookin for one now an the place i went was talking like 900 bucks wtf?
ccvikes11
ccvikes11
im not sure how much it cost because i got it for my birthday but when i get back from vacation saturday night ill let you know who manufactured it.
ezdaar
Chat Troll
Redneck central, Aka Houston
Autozone and pepboys type auto stores sells lift/drop blocks.
Just besure to recheck ubolt tightness after a day or so of driving. The stretch and will loosen up considerably... this will put you in a ver dangerous situation.
rnfernandez1968
