When your windows are up and you are hitting the button to bring them up...you are indeed sending more current to the window motor. The motor is trying to push the window thru the frame in essence. There is no stop on our trucks that i am aware of that cuts power to the window motor when the windows are up, except for the fuse that is going to trip if you hold it too long or the window motor overheating. So in doing this you are creating a huge load from the window motor, hence the dimming of the lights and the voltage dropping. I have had this in every vehicle I've owned, simple solution was to deal with it or dont try putting the windows up when they are already up. If im remembering right, all the electrical systems are fed from the battery, the alternator is just charging. This current drop results from the battery, not the alternator. If it really bothers you that much, I would check your battery or replace with a higher a$$ amperage battery. This is just like the guys who have huge stereo systems in their truck and get lights dimming when the bass hits. Its perfectly normal, something has to give and it results in a current drop. I definitely don't think GM ever planned on someone trying to close windows when they are closed. Hope this helps some, I do electrical engineering, and this is fairly common.
