Lights on doors
JRich305
Miami, Florida
Is there a way to make the lights on the door panels ONLY, not the rest, come on when you open the doors? Thank you.
ScottyBoy
Shreveport, La
It can be done, but not easily. Some rewiring will be involved. Unless you don't want the dome lights to EVER come on, then just remove the bulbs from them and only the door lights will come on.
chauncey0337
MLT, WA
More trouble than it's worth, imo. One way to do it would be to rewire all the lights you don't want to come on into the same circuit as the map lights(if 2000-2002, I believe).
J
JRich305
Miami, Florida
Yeah probably more trouble than it's worth. Wish there was a separate button for it. Oh well, thank you. Lovin the help in this forum.
OmarR
Indianapolis, IN
On 2003-2006, if you want:
ONLY door panel lights to come on with door open
ALL lights to come on with the wheel at headlamp switch
Wire up the following:
Cut the gray/black wire on the C3 plug in the relay block. The relay block has the black plastic cover, and it's to the left of the brake pedal. The C3 plug is on the far right.
The circuit is now separated from the "door open" circuit.
To connect it to the wheel at the headlamp switch, you will need to wire a relay to invert the polarity (from positive to negative):
30 - 12V
87 - gray/black
85 - dark blue/white wire, at headlamp switch or BCM
86 - 12V Orange wire, located right next to the gray/black wire. By using this wire, your interior lights will still turn off after 10 mins should you accidentally leave them on.
By doing this mod, opening the rear hatch/cargo door will NOT turn on any lights.
