Loaded 3/6
O3YUKONXL
Nice ride! Good to see other XLs look so good too. Currently have 2/3 in mine. Looking lower; maybe same kit as you. We often don't travel 'light either. What are your fenders measuring? What size rubber? Have read you to say " want to go lower" - can you "statically", or would only 'bags' get more from this point?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
he wants to go lower in front. He will either need to go with drop spindles and turn up stock keys or go with drop keys and turn them up and get a camber kit.
Pachanga02
Pachanga02
Ny
Thanks, measurement I'll try and have them for you in the next few days. I'm currently on my 22" rims with 305/40 rubber. The front is where I want to go lower, might go with spindles and crank the keys up. I'd like an inch lower in the front.
Pachanga02
Pachanga02
Ny
JD the brackets I used were the stock ones from the escalade but I think you could use your bumpers brackets on it also. Everything is the same just unbolt your bumper and bolt on Esky bumper. Looking at the pic it looks to be the same one.
96ss
Pachanga what is needed to put on rear escalade hatch?
Pachanga02
Pachanga02
Ny
Tyler, you'll need the complete rear glass with the third brake light. If you bought the brake light only, you'll need to drill 3 holes to screw and hold together. Better off just buying it complete if you find one local either scrap yard or craigslist.
raejay
