lockpick with backup camera, can you get factory harness plug pins?
02Lightning
In order to install the backup camera feature on the lock pick it requires you to cut a wire under the pasenger seat. Well I don't want to do that, so what I would like to do is purchase a pin the goes inside the factory plug and get a pick and pull out the existing one. Then replace with my own wire. Does anyone know where to purchase the internal pins that goes into factory plugs?
Fast55
Ventura County USA
Hell, I'd be happy to find the damned plug. there is no plug in my '09 LTZ in the location descibed so for now at least, I don't have that feature.
02Lightning
02Lightning
I haven't tried to look for it yet, I just assumed it was there. I installed the lockpick last night.
RBHoe
Same here- the camera control module isn't under the seat in my 09 LTZ. Anybody know where it is?
ajs800
Michigan
I'm assuming you already have the oem camera factory installed or are you looking to install a camera and run it through the lockpick? If you're looking to install a new camera, there's no need to splice any wires, the lockpick has all the necessary built-in connections.
nevermind...i see that you have a denali, so you already have the cam and are probably tring to tap into it.
02Lightning
02Lightning
what is lockpick? I know thats a noob question but I see that word floating around here a lot
It's a device that lets you watch DVD's while in drive up front, program your GPS and turn the rearview camera on while driving.
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
Which circuit are you trying to tap into?
There is supose to be one under the pasenger seat, instead of cutting the wire I would like to just purchase a pin and pull the factory one out.
91RS
GA
The dealer is probably going to be the best place to get terminals, especially for a vehicle that new. If you knew what brand/style/name/whatever the terminal is you could probably source some online, but any dealer should have those.
DrummerJwatts33
