Long term and short term fuel trims intake leak, low idle, improving fuel mileage. Mpg
afpj
What does your maf read, in g/s, at idle? How old is the maf? The general consensus seems to be that the maf starts crapping out around 140k-160k miles without throwing codes.
Burban22
Burban22
MAF says Delphi in silver plaque on the side. Not sure if its original or has been replaced. Do I need to wait until it’s at operating temp or can I give readings during a cold start?
I have cleaned it a few months ago with the special cleaner spray. It looked clean but did it anyway since I was installing new cold air intake.
This burb used to have an oiled filter open box intake but I didn’t see any oil on maf. The filter always seemed like the oil dried up anyway. I went to a dry filter enclosed box intake.
Burban22
Burban22
MAP Fluctuating between 7, 8 and 9. FYI I’m at 6900 ft elevation if that matters. IMG_1695.jpeg
afpj
I think it's best to take a MAF reading when it's warmed up, but the values for idle that you posted 0.6 3 lb per minute is about 4.8 grams per second. That's just slightly on the low side, especially considering your RPM is 602. My idle typically sits, after warmed up, round 550 to 560. I have a 5.3 flex fuel, stock. Not sure if you have the ability to borrow another MAF that's known to be good and see if your field trims still are that negative at idle.
Burban22
Burban22
Update:
I cleaned my oem Delphi MAF with a q-tip soaked in crc maf cleaner. I gently rubbed the Q-tip on the intake side of each wire, and there was still a little fuzz and dirt built-up that I was able to remove since when you just spray the wires, you can only spray from the downflow side, not the upflow / intake side.
My long-term fuel trims are now -9 and -7 during idle and -4 to -8 driving.
When I have more time, I’ll try putting in the stock airbox instead of my cold air intake box maybe that is causing the negative fuel trims?
Recently went on a 400 mile road trip and got 16 - 17 miles per gallon driving 65 which seems really good for a 2003 suburban 5.3 4WD Z71 3:73 with 2” lift.
Burban22
Burban22
Sending off all 8 injectiors to this cleaning service. Comes out to about $10 per injector. They don’t give flow rates or anything special but have good reviews and I’ll update if my LTFT improve from the -10 through -3 I’m currently seeing once they are clean and reinstalled.
When you get them back, a good bi-directional scanner can perform an injector balance test, along with a fuel pressure gauge.
2006Tahoe2WD
Silicon Valley
I'm curious to see if your LTFTs change. I'm running +2-4% at idle and ~+10% on the highway. I'm thinking the injectors are not flowing enough and the "+" values are caused by the ECU trying to get more fuel.
Burban22
Burban22
Received my cleaned fuel injectors back with new upper and lower O-rings although I had to replace the lowers with the originals as the O-ring they included were just a little bit too big and I couldn’t get the injector all the way in the intake.
The place I used only charges $9-$10 per injector after shipping so they don’t include flow rates.
My injectors do look much cleaner and they replaced the screens inside the injectors and the lower plastic caps.
After all this, my fuel trims are now taking away even more fuel, -12.5 at idle but -3.5 to -9.5 driving. I’ve only driven it once since resetting the computer as the battery was unhooked for a few days.
Suburban runs the same. Will see if there’s any fuel mileage improvement, but I would assume the injectors were dirty after 170 K miles and 20 years.
Firefiterp
