Long tubes and factory exhaust
brotten
Kansas City
Has anyone on here ever ran long tubes header with an electric cut out back into the factory exhaust system?
Z-56 Hoe
What do I do????
Houston
I've been here since the start, and I can't remember anyone running a setup like that. Why the Factory muffler?
Big Buttons
The SS Burb
South Texas
I've seen similar set ups like that but really there is no point of using that oem muffler. I have a cutout on mine exiting basically right under the pass door. When it is closed it goes out the back to a flomaster super44. If you dont want something that loud get a magnaflow.
brotten
brotten
Kansas City
I've ran out and cut the exhaust off of every vehicle I've owned in the last 16 years but now that I having sleeping kids it's nice not to have loud pipes and annoying drone on long trips...
shakedown067
I have longtubes with cats and stock muffler, for now. The ZO6 heads made it a tad louder and the rasp a bit more pronounced though. Have a custom magnaflow system in the works.
[yt]buOEpXlsNGU[/yt]
Mr. Merk
241 Heads are off of LS1s. Are you sure you didn't get 243s? Those are what comes on Z06s and 07+ 5.3s. Only the Z06s had the sodium filled valves.
Also how much did you mill them? I know 243s need .020-.030. They 241s need even more due to their larger CC
shakedown067
Hmm, I'll have to look into it. I know the shop said they had the sodium filled valves, not that I was looking for them. Maybe they were added on with the car's previous build. They are 241's and from all I read didn't need to be milled down, although I should have done it anyway for a slight boost in compression. Hope to get it tuned on the dyno after the exhaust is done and see what kind of power she puts down. She certainly had a very noticeable increase in mid-range power, slightly better in the low-end.
Mr. Merk
If they weren't milled, you definitely lost compression.
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Material: Aluminimum
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Valve Diameter: 2.00 inches
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
shakedown067
Well, guess I should have tuned in here sooner. I knew I should have milled it. I'll just need to slap on a supercharger. :p
Charlie T
