Looking for advise on ANCEL V6 PRO+ Bidirectional Scan Tool
j91z28d1
I don't know if that will program modules and flash stuff for you. but if you just need a good scanner. just spend half that and get a tech2. it will do basically everything you will ever need from these gm's.
opfor2
opfor2
Riverside County, CA
do you not need a yearly subscription for the tech 2
j91z28d1
not just to view data, codes and run special tests. but you also can't update the cheap clones at this point. newer cars have moved on to newer dealer scanners.
if they work for your truck. I recommend spending the 200$ on one.
there's also a super long thread about them here and a map of locations of guys with them that might be willing to help people with issues.
opfor2
opfor2
Would I be able to update any of the information to include newer vehicles and is it only for GM ?
JKaechler
I would also like to get my hands on a Tech2 or a clone if such a thing actually works. But I am still trying to learn exactly what the Tech2 is. It seems like the go-to tool for a lot of things that I and others in my family with the same general year range of GM trucks and SUV's could use.
j91z28d1
a tech 2 is what the dealers used to use. it basically did all the functionality stuff it could do. the dealer has moved on thou. it's out dated tech at this point. like mine won't read my 2014 volt, but it will read my 11 yukon.
the original ones were like 2k$ which was a lot back then, now eh.
the story I heard was like everything, the oem one was made in China like everything electronic is and when the factory moved on, they kept making them, with a software that worked without needing to be on the dealer wifi and log in but I believe they won't flash modules like the oem ones used to. but as a diagnostic tool, if you have something with a shop manual level of troubleshooting tree in it. the 300$ ones will run all those tests.
for example say you have a door lock that doesn't work with the switch, you go into the tech 2, command the door to lock. if it works you know it's the switch, if it doesn't you ruled that out and on to the next test.
I got mine from a link here. there's a long tech 2 thread. shipped from China directly. I think I've seen a post saying they don't sell them anymore thou. probably moved on to the newer harder you use laptop based but I believe it will flash modules and stuff. so I'll pick one of those up at some point too.
Aviator_78
