Looking to buy
sennister
Grant, MN
Around here in MN we were seeing 07-08s in the 20-25K range with mileage in the 80-105K range. Granted we were more focused on the LTZ. We wanted the Nav not so much for the Nav but for the full size screen for the backup camera and DVD for the kids. We have a camper so the ease of hooking up a trailer is worth it. Many times my wife will hitch up the trailer and I meet them at the campground. Sure you don't have to get a LTZ to get these items but they were more common in them. In the end we ended up with a 2011 Denali with 96K that was equipped like I would have ordered it for $27. Every option but 22 rims and power running boards. Though Denalis have a pretty short list of options.
Some issues to watch for. A buddy of mine had a 07 Z71 Tahoe and had the oil consumption issues. This will be hard to spot in a test drive but he was burning 1 qt per 1000 miles. I have seen some talk of new valve covers which address this. I thought he said they replaced the heads in his but he isn't really technical when it comes to cars so he wasn't sure. I want to say that it was around 2010 that they made some changes to address this.
In the 6.2 found in the Denali and Escalade (also some Tahoes 09 I think) there were some issues with cam bearings. 09 addressed that also adding flex fuel compatibility. 10 they added active fuel management. While the Denali and Escalade will get get worse mileage because the bigger engine and AWD, it isn't much. 1MPG or so if you take it easy but that isn't easy. I have noticed that it gets better mileage than the 03 Avalanche that it replaced.
The dash cracking is pretty common as you noted. Mine isn't cracked at all. Another common issue is the door handle on the inside of the truck. The chrome plating (wrap) peels off leaving the edges sharp. A Tahoe Z71 I drove was like this. They are not too expensive to replace. I want to say I looked them up and they were $15-20. A common issue with used vehicles is keys. My Denali came with 1 key and 1 fob. I negotiated a second fob and key in the sale. I asked about additional keys but they said the fobs were really expensive. They also would only let me have 2 keys as part of the deal. I went to another dealer closer one day and had 2 more keys cut ($30 a pop). In 2007-2010 you can program fobs and keys yourself. You can get them cheaper on ebay or other places. In 2011+ you have to go to a dealer or someone with a Tech2 programmer to add fobs. Keys can be programmed though in all of them.
The 15K budget may make it hard. You can probably find them out there in that range but it will take more time. Of course if you are fine with the lesser equipped LT range then that will make it a bit easier.
Tahoemonster
Well I have a 2008 Black Z71 Tahoe with 177K miles and it drives like a champ. It's a Chevy and Tahoes can last 400-500K miles, with no problem. I am the original owner and I've taken meticulous care of it. Even had a $600 paint correction done to it (which is basically a very intense detail that removes all swirl marks from the paint)...I'd put my Tahoe's paint up against any 2013 or 2014 Tahoe...it looks that good!! It's actually for sale on cars.com. If anything else, look at the pics so you can see how clean it looks for 177K miles and feel confident if your on a budget and in the market to to buy a high mileage Tahoe.
So in essence, it's all relative. A good Tahoe can be had for 15K if it's been well taken care of.
Fir_Na_Tine
Fir_Na_Tine
Well my search has ended. My wife found this Tahoe online over the weekend and after checking it out we bought it. Its a one owner 2007 LT with only 50k miles on it. It was just traded in on Saturday and just put up on their site. They didn't even detail it yet and fix a few a few things it needed, which they are going to do before I pick it up in a few days. Drives and feels like new too.
It doesn't have all the bells and whistles like the others I looked at Saturday and have seen online. Cloth seats which is fine with me, not a huge fan of leather as its cold in winter and hot in summer, plus they need more maintenance. No DVD TV entertainment system which nowadays most would use a tablet with movies loaded on it. The only thing I wasn't crazy about was the rims and tires, I liked the look of 20 inch factory rims and low profile tires. This has 17 inch rims and more thicker sidewall. But still ok. If I want I can add bigger ones later. My main concern was that it has low miles and taken care of maintenance wise. Also got a 4 year warranty with it. And the piece of mind of buying from a reputable 50+ year Ford dealer (of all things) instead of a used car lot that may or may not be there in a year
Hopefully it will last me for quite a few years.
sennister
Grant, MN
Congrats on the new ride. If it weren't for heated and cooled seats I would agree with preferring cloth. While I have the 20s and like the looks, many times it is better to have the thicker sidewall. Less likely to jack up a rim if you slide into a curb in the winter. Not that I am willing to give up my factory 20s but I am actually considering another set of rims in the 17-18" size range for winter. Winter is about over here now so I am not going to mess with it right now but I am going to look around.
GalaxyBlackEsky
BlackedoutLT3
MD
Seems about right as well. I sold my 07 Tahoe with 131k for 19k. But also it had some mods on it.
Fir_Na_Tine
Fir_Na_Tine
I was wondering what the exact size, offset or part number the stock 20"s are. Where would be the best place to get them? Junkyard maybe? I figure the dealer would be most expensive. I saw replica ones on Ebay but unsure of them. Or would it better to just get similar aftermarket ones?
sennister
Grant, MN
Not sure off the top of my head. I know the 20s on mine are OEM because it is the Denali which comes with the Chromed Aluminum 20s stock or 22 as an option. Junk yard is a possibility. Try checking Craigslist. You may find someone upgrading OEM rims and want to offload them. eBay may be another source but shipping may be expensive. I have a cousin that works at a junk yard so I have him keep an eye out for some and I can get them pretty cheap.
For instance here is a set in Minneapolis not far from me.
http://minneapolis.craigslist.org/hnp/pts/4877744410.html
Fir_Na_Tine
Fir_Na_Tine
Thats a pretty good deal. But yeah buying online shipping would be a killer.
Wash114
