Loose rattle sound in the front end
rms25thta
NC
Has anyone had a issue with a loose rattle sound coming from the front end in their Tahoe?? My 02 has it and happens when I go over a bump especially at slow speeds. Just wondering if any of you have any insight.
Rich
Shaggy
Admin/Owner
Administrator
Arizona
Have you checked the bolts to the front bumper to see if they are loose?
R
rms25thta
NC
um.....not the bumper.....it is the intermediate shaft in the steering I found out.
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
what part of the shaft is that? i have same problem and i have steering problems too, its hard to turn it to the right only like there is no power steering and then its totally fine to the left
R
rms25thta
NC
I don't have any issues with turning, that sounds like your steering box. Mine just rattles when I go over bumps like I have a loose component in the front end but it isn't. It is the intermediate shaft in the steering. Do a search for it over on gmfulllsize.com there are tons of post about it.
Volant1
Volant guy
Upland, CA
There was a recall on the older year tahoes steering shaft, If you here a loud pop at max turn, you need the new shaft. I can give you the autozone link if you need it
tybardy
everyone needs a Hoe
Gilbert Arizona
i have a rattle EXACTLY like that and it is NOT the int. shaft.
Going over bumps never seemed to effect my bad shaft (yes i had that problem too) however there are also some weak points in the font suspension.
llisumm
