Loose rear end...
06xl
MD
I've noticed when I hit a bump the rear end feels like it wants to break loose if you know what I mean. The front handles it fine but the rear sort of wants to fish tale . Is this common because of the truck being a XL and no weight back there?? or is it possible that worn parts in the rear may cause this feeling?? If so what should I replace?
06xl
06xl
MD
Anyone?? Tony were r u??
Sasquatch
Orange County N.Y.
Do you have auto ride? My yukon has it and when i hit a big bump it seems to do what you`re explaining. It only happens at highway speeds.
I have been in a non auto ride tahoe/yukon and it doesn`t happen.
06xl
06xl
MD
Sure do have auto ride and same here only hwy speeds. I'm wonder if leveling out the rear and adding a thicker sway bar with poly urethan bushing will take Care of that....
06xl
06xl
MD
Which one you think rides better non auto ride or auto ride????
Sasquatch
Orange County N.Y.
I think autoride gives a smoother ride but there isn`t a huge difference to me.
If you ever wanted to eliminate the autoride you can always install regular shocks and if i remember correctly just remove a fuse to disable the compressor and any trouble codes.
CoyotesRUS
