Loose rear sway bar link
MacG
Hello everybody,
just wanted to first say thank yall for your quick responses and helping me figure out what’s going on with my Yukon
I am having a wobble in between 30-40 mph and I was just up under my rear suspension and could by hand undo my rear sway bar link, it probably had half an inch of play, could this be enough to cause a wobble?
Thank you fellers
Hello everybody,
Thank you fellers
possible depending on how exactly the wobble occurs, tighten it up and check the front as well.
sway bars should never be loose, best to give everything a good inspection in case something else is not right.
EjDied
