33's and a lift would drop your MPG prob 1 or 2.. The light bar, prob only at
hwy speeds maybe a hair...
You might want to clean the MAF and the Throttle Body...
I would suspect that your upstream Oxygen Sensors may be off, esp
if you've been running really rich... O2 sensors are kind of a tune up item..
I don't see the evap code causing any MPG issues, although very annoying..
I wonder if the shop that jacked up the O2 sensor wiring got into the vehicle
side of the O2 and "repaired it"... You can't extend or really repair O2 wiring as
it screws up the relationship of the voltage... Check to see if that's the case..
If so, find used wiring harness for the O2's or see if gm still makes it
Thank you Foggy, I have a brand new ACDelco MAF I just installed after I herd about the other ones being problematic. The TB is clean as a whistle and I even threw on a new MAP for good measure. I asked the mechanic to check out/inspect the O2 wiring and he said he did...I also think he was more inclined to wanting to prove me wrong and himself right about the trim levels.
Before I had the latest work done I happen to see this (pic) right under the pas. side door. thus why I asked for them to inspect the wires..
Whats the weight difference in the current tire/wheel combo vs. what was on it? When I put some 20s with 305s on my Dmax in place of the factory 17s with 265 I lost fuel mileage. The 20 are heavier..
Surprisingly there was little weight difference. I was expecting more for sure. The ones that were on it were 265/70/17 E ....and I replaced those with a
BFG 285/70/17 E
Think it only increased the size by an inch overall in ht. I wasnt expecting to find load range "E"s on it,...I thought they were "Cs" all along.
10-12 MPG city is normal for the 5.3L engine most areas have adjusted the traffic lights so you burn more
fuel
the worst i have ever gotten in my 3.8l was 12MPG in the metro area years ago so yeah your tahoe is sipping fuel.. even the 4.8l sips fuel more efficiently
It's a Conspiracy to boost up the oil/gas prices
Now on to the CEL
P0446 is a restriction in vent "solenoid" this is a electronic code not a cat code(if it was the cat you would have a P0420/P0430 code)
so you have an issue with one of the following:
Baro(MAP sensor)
MAF sensor
IAT sensor
ECT sensor
Ambient air?
TPS_FA (Throttle Position Sensor)
Vehicle speed sensor
engine power limited
Thank you BG.
If 10-12 MPG is normal for the 5.3s than you made my day. (really) not even being sarcastic!, all I could find were higher numbers.
The vent solenoid has been replaced about 4 times now. The MAP, MAF are new. I think Ill be checking out the TPS next. Before I had this shop work on it, and they reset the Fuel trim..my gas pedal seems to be less responsive by just a bit. It seems like before if I gave the pedal a tap while idling the RPM needle was faster to rise than what it is now. Now it seems to just kinda creep up and fall just as slow... Maybe my imagination? but I remember that was the first thing I noticed when I got it back from service. I was thinking the computer may need to relearn?...
Brandon, do you have one of those Bluetooth OBDII adapters and the Torque Pro app or Dash Command for your phone? If not, get it and set it up to read your Long Term Fuel Trims and Alcohol Content. Also set it up to look at all 4 of your oxygen sensors.
I suspect that your cats are slowly failing, this is what happened to mine a few years back. More recently, one piston on a front caliper was causing the pads to drag on the rotor and got progressively worse, cause the steering wheel to wobble and then a few months later it locked up and smoked the brakes on that side. Anyway, pull the wheels and check that out too.
With the O2 sensors, you are looking to see that your upstream sensors are moving continually while cruising and that the downstream sensors are fairly steady. If they are moving like the upstream sensors, the cat(s) are no good.
The LTFTs can identify all sorts of problems, if high while parked at idle, that's usually a sign of a vacuum leak (like intake gaskets). But don't freak out when they're -25 right after refueling, the computer is figuring out the alcohol content and adjusting for it. The computer needs at LEAST seven miles or so calculate a new alcohol content after refueling, it is not good to fill up right down from the house and then go home all the time. We often fill ours up about 20 miles from home and it begins to settle down at the end of the highway run but still usually fine tunes itself the next day, or two or three!
Your truck was originally rated for 14 City and 20 Highway. Knock off a couple MPGs for the lift and tires. The average economy of these trucks across all models and years (5.3 engine) of the GMT900 is 14.3 MPG according to research done on Fuelly. My truck's average is 14.8 MPG on 93 octane gasoline (E10).
Any stations with Ethanol nearby? I mix E15 or E10 with E85 and average 15.6 MPG while getting the benefits of high octane fuel at 87 prices.
Do you have a suggestion as to what OBDII Bluetooth to get? I remember your posts and warnings about the brakes and the little spring, The truck seems to coast like a dream and the guys doing the breaks used ample lube on all the friction areas. (I can see it)
I've talked about the cats here before and with only 73k on the truck... do you think its likely? It does smell like Im roasting coffee if I really get on it.....its either coffee smell or something similar to two part epoxy curing.....
With the reset of the alcohol content after a fill up, Im under the impression that the system closes the loop temporarily by closing the purge solenoid. It crossed my mind, (and if I understand the system correctly) that if Im getting a PO446 maybe I need to check and see if Im getting power to the purge solenoid? I mean,..dang thing has been changed 4 times now trying to fix the fill-up issue and code. Maybe there is a problem with the power going to it?
7 miles! I've been looking for that little bit of information for a long time now too! I even asked the mechanics and non of them knew!
I never make it more than a 1/4 mile until I get home and shut off the engine after a refill. You always full of good info swathdiver!
Are there any particular problem areas on the 5.3s that I should check extra close for vacuum leaks? The elbow going into the brake booster turns pretty freely and I've been meaning to change it...
Im off the Amazon to shop for OB2II Bluetooth gizmos...
Thank you!
