shorelocal
My '06 Escalade is losing coolant and I'm not 100% sure where it's going. Noticed the coolant reservoir was almost empty, then noticed a pool of liquid on the garage floor that felt slippery to the touch ... definitely coolant. Didn't initially pay any attention to the wetness on the floor because we've had lots of rain and snow, so the truck naturally drops moisture on the ground in this weather. I've topped up the coolant reservoir a couple times now with distilled water and it's definitely leaking somewhere. Oil on the dipstick looks fine .. not milky at all. No smell out of the tailpipe either. No wetness on the passenger side floor, no smell inside the truck when the HVAC is running, and the interior heat seems to blow warm and normal. I left the truck running and looked all over the engine bay and under the chassis ... noticed a drip falling to the floor just behind the passenger side wheel. Looked in the engine bay again and there is a pretty regular drip coming from the heater box drain hose ... that little "L" shaped rubber hose piece just below the AC accumulator.
Question: is this a drain for the heater core? Is this a sure sign my heater core is leaking?
