RichardCranium
Experienced a weird one last night, wanted to run it across the forum to see if any of you guys had experienced anything like this.
Last night, I started the Tahoe and immediately noticed the ABS light was on and none of my needle gauges worked in the cluster, except for the voltmeter. All of the cluster lighting worked, however. The DIC was displayed dashes in place of number values for the ambient temperature, etc, as if it wasn't communicating.
I drove home without a hiccup until I got about 10 miles up the highway (I was a mile from home at that point). I stopped at the store and threw in my OBD2 tester, and found no codes present. At the same time, while I was key on/engine off, the gauges started working. I started the truck and found the truck was overheating (normal is straight up at 210 degrees, I was about 230 which is about 2/3 of the way up). I drove home and it cooled back down to normal, then started to creep up again as I was turning in my driveway. I did smell coolant, but didn't really see any evidence of a leak. It was tough to determine though, since it has been raining all week. I did notice the fan was operating.
This morning I got in the truck to head to work, all gauges are working fine. It was in the upper 30's outside, so I turned the heat on and headed off. Usually the ~1 mile drive to the interstate is enough to get some heat, but it was stone cold. The temp was a full 210 degrees by then, like normal. I hopped on the interstate for the 10 mile highway ride to work, and found the temp crept up to 230-235ish and didn't venture any higher. If it went up further I was going to pull over, but it sometimes crept back to the normal side and never went over 230 or so. I cut the AC on to pull the fans on, but it didn't make a difference with the engine temp. Even with the AC on, I did notice some heat from the vents....which was weird and short lived.
Going to take a work truck home tonight and leave my 'Hoe here until I figure out a game plan. Wanted to see if anyone had any experiences similar to give me some direction on what to look for. FWIW, 2010 PPV Tahoe 2WD, MFI.
