bunchz71
- Joined
- Mar 29, 2016
- Posts
- 162
- Reaction score
- 30
OK, for a whike now, on my 1999 2 door tahoe, my low beam headlights would intermittently not work. With the DRL fuse in, low beams worked. But when low beams were turned on using the headlight switch, they would go off. Bright lights would work but low beams would not. All fuses were good and bulbs were good. I did finally figure out my low beams would work when the tilt was all the way down, but if tilt was up at all they wouldn't work. This told me automatically there was a broken wire. After some online research, I was convinced it was the multifunction switch, which controls cruise control, blinkers, wipers etc. I tore down the column last night and found what I expected to find. Cheap fix. $46 on Amazon.
There is a great guide in how to do this in youtube by 1A Auto
