Antichrist
- Joined
- Jul 27, 2011
- Posts
- 18
- Reaction score
- 0
Problem with idle, slow start and occassional no start.
1995 Chevy Tahoe. 5.7 TBI. Automatic. 136k miles.
In park: Idles ok at around 900 RPM, but a little rough. Giving it gas up to 2k RPM in park, engine shakes when decellerating.
In gear: Accelerating/High RPMS the truck runs like it was brand new. When I stop at a light, RPMs drop to 500, Idles rough, and RPMs fluctuate intermittently, dropping below 500 RPM, then correct themselves and come back up to 500 or so.
Also had a stalling problem, replaced MAP, and the truck no longer stalls when I come to a stop light. When it DID stall, It would start right back up with no issues.
It still takes 5-8 seconds of cranking before the truck will start.
I have had the truck not start for me twice. One time it took about 10 minutes of repeated cranks before it started finally. The second time I gave up and got a ride.
So far: Dist cap, plugs, wires, all check out ok. All terminals inside dist cap were cleaned. Ignition coil terminal cleaned. Otherwise No burns, cracks, etc.. wires/plugs were just done about 5k miles ago.
EGR: With engine off, diaphragm movement has resistance. Engine on, more resistance, when I push diaphragm, engine runs rough.
IAC valve has been replaced with a new one, no change in idle. I also tested a used IAC that I had, and no change. With truck running when I unplug IAC, there is no change in Idle.
TPS has been back probed, showing 4.55v with throttle plate closed, as I open throttle plate, voltage slowly decreases down to about 1.25V
Coolant temp sensor (sender?) has been unplugged, and truck runs the same. This is the unit between #1 and #3, in cyl head.
All fuses have been checked, and are fine. I used sandpaper to clean all terminals of fuses in engine block fuse block as there was a slight varnish on the blades. After doing this the truck started PERFECTLY, with a 1 second crank. It only started like this ONCE. After that, it was back to 5-8 cranks before it would start. I'm not sure if this was coincidence, or not.
When driving with a cold engine (ran for about 1 minute before driving) on a 50 degree F day: Acceleration is sluggish, if I give it too much gas too fast, it acts like it wants to stall. After the truck warms up, RPM idles at around 500, once I get over 1k, I can give it as much gas as I want, there's no stalling, no misfires, no pinging, no knocks, etc...
When RPMS drop to 1k-1500RPM when holding steady speed, the roughness comes back.
When I'm at a stoplight, and the RPMS start to drop below 500 and the truck starts running really rough, I can shift into Neutral, and the idle immediately returns to normal.
Everyone keeps telling me it's the fuel pump. I seriously don't think the fuel pump is an issue.
I bench tested the fuel pump relay, and it operates fine.
I listened to the relay with a stethoscope when installed, and had my girlfriend turn the key, and it operates fine.
I could never hear the fuel pump inside the truck, so I listened with the stethoscope underneath the truck, and the fuel pump runs fine.I had my girlfriend cycle the key on/off several times for the relay, and the pump, and I have no change in performance, sound, duration, etc....
Please help.. this is driving me nuts.
