Low oil pressure and lifter tick...GONE!
SDuncan2006
North Florida
My 2006 Suburban never did have sufficient oil pressure to suit me. It got to where the most i could get under acceleration was around 40. Also, it began to drop to 0 at a light every so often. Put it in park and rev the engine to oil pressure up. Around town i never got any lifter noise but on the interstate at 2k rpm and above..the clicking would start. It was time to bite the bullet with a new oil pump.
I went with a Melling 295HV pump. It is reported to have 18% more volume than stock. It comes with high pressure spring installed and lower pressure spring in the box. I left the high pressure spring in. Also dropped the pan and replaced the pick-up tube while I was at it. Trust me, it is much easier than monkeying around with the one bolt on the pick-tube with the pan in place. new oil pan gasket and the proper torque and no leaks. BTW, I didnt need to replace pick-up tube. I just wanted too. The original was super clean.
Now it idles at 40-50psi and cruises at 60-70 on the highway! No more lifter noise either!!
Good save. It's crazy how the one component of an engine that's moving internals are constantly immersed in oil can wear out.
SDuncan2006
SDuncan2006
North Florida
Yes. I wasnt sure if pump just got weak or if pressure relief valve was stuck open?? New pump needed regardless. Best 200 bucks I've ever spent.
nikogto
Mooresville NC
Nice to know you saved it, I've got the same pressure you do now, but on my 224k engine. First I've seen on a bad pump, usually the o-ring on the pick up tube goes bad and looses pressure.
thewheel82
