Lower Control Arms ID
zomeizter
North AL
Stamped steel, welded or forged LCA? I went and looked at it with my flashlight and it looks like the bulk of it is stamped steel with a solid piece where the BJ is pressed, connected to it by rivets, or something like that...it's dark out there and I need to order replacement BJ's, how do I properly identify these without actually removing the BJ and measuring? Thanks.
zomeizter
zomeizter
North AL
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
---------- Post added at 05:47 PM ---------- Previous post was at 05:44 PM ----------
Do these pix mandate a welded or a stamped LCA? Technically it is a stamped LCA welded to the piece that holds the BJ, kinda confusing, and there are three different sizes of BJ's and I'd hate to order the wrong one. So, which is it boyz?
zomeizter
zomeizter
North AL
found hardware on the top joint but the lower one is pressed in, but I guess I will have to remove it and measure its diameter because the LCA is a stamped steel piece welded to another piece that holds the BJ, so this LCA could be called a stamped steel or a welded one. Thanks for the help man...
HAIGDEDNEDNA912
