I wanted a slight drop in the front without going the spindle route again. I ended up getting a set of MaxTrac 1" lowering springs 251510-8 and cut down my auto ride links .400" in the front and that was the solution. There are detents in the factory auto rid link and I simply cut off the upper detent and used the lower detent and that worked fine. Getting the springs in was a different story, the front struts have an magneride connection that has to be removed in order to get the nut off the strut to replace the spring. That required a visit to two different local GM dealers to get that accomplished, but the job is done!
I have NorcalSS's rear lowering kit in the rear and the MaxTrac springs in the front. The finder lip is ~34" front and ~35" rear now.
I also got some new LED fog light bulbs and color matched the Bowties with some Avery brand (SW900-109-S GLOSS WHITE PEARL) vinyl wrap off of Amazon that matches extremely well!
Check her out!
Check her out!
