lowering front end???
Blacked-out-Tahoe
Washington
what should i do??? i lowered the rear of my 04 tahoe 3 inches and new upper and lower spohn control arms and end links< but now i am stuck with the front end a little high...
so here is my question should i do drop spindles or drop tubular upper and lower control arms?/
JKmotorsports
Austin, TX
The spindles would be a lot cheaper, keep everything in correct geometry, and if you dont adjust the keys or swap anything else, you won't need to re-align.
JKmotorsports
Austin, TX
Really? IIRC, I thought when I was looking the tubular control arms were over $400 a set compared to about $250 for the spindles. That was about 5-6 yrs ago though last time I checked, unless I'm thinking the other way around on the prices.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i have the belltech spindles for 280 shipped and will handle fine buttttttt my question is how much lower is the rear than the front of your truck
If your rear is only 3/4 of a inch lower you can do keys for 1 inch and be fine but if you need more than 1 inch I would do spinldles
Blacked-out-Tahoe
Blacked-out-Tahoe
Washington
i need to drop it 2.5 to 3 inches to get to sit the way i want it to. but i want it to handle like a beast i want to make this a track rig/ auto cross tahoe
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
DJM 3 inch lower a arms with qa1 double adjustable shocks. It will drop the truck 3 inches in front and comes with poly bushings and new bjs. Ill pm yah
dylansmashed
