stagrlee
Thank you sir. This is the stuff I need to see. Which balancer did you use and did your accessories from the 5.3 line up? I'll try to get a look at the oil vapor system you used. Please feel free to post up any other details you can think of.
I'm using the factory harmonic balancer. Wonder if that was a mistake on my part. Since I'm using a low RPM torque setup vs high rev, its probably not a big deal.
The 6.7L motor is the same block - just bored and and different crank/rods/pistons. So everything bolts up. The whole line of LS motors is plug-n-play swappable parts, that's why the Corvette valley cover can be swapped in. You can go nuts thinking about different intake, cylinder head, crank/rod/piston setups. I differed most of the thinking to Texas Speed and Central Texas Performance opting for factory cylinder heads as my wallet was getting drained...
Lots of writeups on the conversion. Can't find the one I followed, but they are typically called PCV delete or LS6 valley cover swap. This one is pretty good.
