Lug pattern Swap 94 obs to 96 obs tahoe
ogrybeee
Okay so a buddy of mine has a 94 obs 4wd 6 lug sitting in his yard and i have 96 obs tahoe 2wd currently 5 lug. Is there any way we could swap the lug pattern or some part so i can get the 6 lug pattern
Squirrelsmith
There are adapters, i have read a lot of bad things about them though
73impala
Margate, FL
From what I recall the rear axle is an easy swap but don't remember the front.
Edit:
Just did some searching the 4wd axles are wider for people lowering trucks that's an issue but if you're not then it might not bother you
randeez
south florida
rear, you can swap the entire axle but it's 2-1/2" wider iirc, replace axle shafts in your current axle, or run adapters.
front, you can run adapters or swap to the light duty 2500 rotor/hubs - may require you to upgrade calipers (i think there are 2 different rotor thicknesses for 1500s, youll need calipers that work with the thicker)
McRib
