Magnetic Ride Control and Automatic Level Control (ALC)
rockwoodroo
I got my truck (Tahoe 2017 LS) with the "Max Trailering Package" which includes the level control.
Does anyone know if ALC includes the magnetic ride control?
Also is there any way to disable the level control?
GU6 is your axle ratio which means you have 3.42 gears.
G1E is your paint code for the exterior, siren red tintcoat.
G80 means you have the locking differential/positraction differential.
ZY1 means you have one solid color of paint on the exterior.
Z49 has to do with mandatory Canadian base equipment, whatever that means.
Z82 has to do with your trailering equipment.
Z85 is your suspension package, whew! For 2017 it's called Premium Smooth Ride with Air Leveler.
NHT is your max trailering package.
You do not have the magneride shocks, they are associated with Z95.
Chevrolet will send you an email with your build sheet decoded, you can also pay to get actual copies of the paperwork used at the factory to build your truck. You can also decode your VIN at Compnine.com for $5.
AZRiverRunner
The Canadian vehicles can't disable the Daytime Running Lights, that we can in the US.
bigtoe
