Manual Park Release 2021-2024 Models For Towing Or Other Reasons
jfoj
Not sure about pre 2021 vehicles, but the 2021-2024 with the electronic button shifting cannot be manually tanke out of park from inside the drivers compartment. The parking pawl is /Elecrically and hydraylically controlled. So if the engine does not start and is not running and/or there is a problem with the transmission, you cannot get the transmission out of park.
If may be possibly with the 4 wheel drive versions to get the transfer case into a Neutral mode to roll the truck, but this will at least require battery power. Additionally, it is my understanding if the transmission parking pawl is manually overrided, then the electric parking brake will engage as a safety feature if the vehicle has battery power. I have also found info if the manual park override is used, it may store a transmission related code in the PCM?? A standard OBDII scan tool may be able to clear any codes/errors tha may be recorded, but I have not had a chance to walk through the complete process to see how the electric parking brake behaves and if any codes may be set if the PCM.
All of the above stated, the transmission park can be overridden with vice grips, an adjust wrench, an open end wrench or even with the GM special tool DT-52910 Manual Park Release Tool.
Depending on the situation, you may need to roll the vehicle to jump start, tow or for some other reason. The issue with manually overriding the parking pawl from under the car is SAFETY. The vehicle CAN AND WILL ROLL. YOU MUST DO THIS CAUTIOUSLY. Possibly even having wheel chocks or someone in the drivers seat to manally apply the brakes.
The tricky part is if the electric parking brake is automatically enabled, this may cause some problems depending on the vehicle electrical system. So this is another thing to think about and may need to be bypassed. Most of the bypass suggestions seem to suggest unplugging the parking brake connectors at the rear calipers, but there may be a fuse/relay that can be pulled rather than unplugging the emergancy brake wiring.
Here are a few good YouTube videos that give you some ideas of what you need to do to bypass the parking pawl in the transmission.
Additionally the GM special tool can be used. DT-52910 Manual Park Release Tool is about $300 depending on the sources you find it available from. I am planning to install this DT-52910 Manual Park Release Tool in my vehicle permemently and possibly route the cable into the driver compartment so the parking pawl can be release from the driver seat. We will see if this is possible. The DT_52910 comes with a 6 1/2 foot cable and you can easily remove the release end but would need about a 1/2" hole to pass the cable end into the driver compartment. A splt grommet could be used to seal the hole and protect the cable jacket. The tricky part would be somehow mounting the release handle as it is really not designed to be mounted, but it could be stored under the dash with some bread ties to be removed for access as needed. Will see how all this goes and if it works out as planned.
Update!!
So today while it was warmer out I installed the Manual Park Release tool in the truck. I should have put the truck up on ramps, but had a slight dip in the driveway where the truck was parked. I was able to crawl under and instal the braket on the transmission, this is pretty easy. The tricky part is some transmissions may have a threaded shaft, mine did not, so there is a locking collar with a 2.5mm hex head screw that clamps the collar on the shaft on the transmisson. The issue is the bracket that slides on the shaft floats and there is not a good way to make sure the bracket is tight the way things are designed. I installed 3 flat washers I had laying around to take up some of the space so the bracket was not wobbeling around as much. I think I need to find and add a wave washer to preload the bracket slightly, but the washers helped quite a bit.
Routed the cable up under the hood for the time being, it may stay there, not sure. So for now I just need to pop the hood and pull the loose end of the cable up so I have access to the handle to release the parking brake.
I still need to come up with a full process on how to get the vehicle in Neutral without trigger the parking brake. I have some ideas other than unplugging the connectors on the rear calipers. I did a quick test and when the cable handle was pulled the transmission selector Neutral light was blinking and the dash display indicated N.
I did get a pop up message to Service Transmission on the dash display, it did seem to clear once I released the Park Release handle, but I will need to follow up and see if there are any permanent OBDII transmission codes. I actually did have the SES/CEL/MIL light on after starting and driving the truck. 2 codes, P0700 Transmission Control Malfunction and P187E Transmission Park Valve Stuck Off. These are expected unless the battery is disconnected prior to using the Manual Park Release. The codes would also not likely be triggered if the ignition is not turned on. I turned the ignition on to see if I could get the parking brake to release, did not have luck, but need to try a few other things to see what happens. These codes and the SES/CEL/MIL should clear on their own after 10-20 start cycles, or should be able to be cleared with a standard OBDII scan tool or App and interface. I have not had a chance to clear the codes yet, probably try to do this in the next few days.
At least I now have a Park Override installed in the truck if I need it for any reason.
J
jfoj
I had seen that bulletin, it is a bit dated (Dec 2021) as I can confirm at least thru 2024, this same tool and procedure works. While I have not looked closely at the 2025, I beleive they may have a column shifter as I recall seeing one in a picture from the drivers seat. But I have not physically seen, driven or spoken with anyone that has a 2025 model yet.
The 2025 Tahoe has an electronic, column shift lever. It is awkward, flimsy and not intuitive.
To shift to drive or reverse, you pull the lever toward you, then move it up or down to place the transmission in forward or reverse. To shift into park, you push a silver metal button on the end of the lever, which places the transmission in park and sounds a chime.
J
jfoj
Sounds like the 2025 has more of a faux column shifter. An electronic mechanic shifter!
Anyone that has a 2025, sneak under the truck and check to see if the transmission is the same as the 2021-2024, I assume it is. If so, the same cable assembly should work and the same park release hacks should work.
J
jfoj
Updated the first post with a few more pictures now that I have installed the Park Release cable in the truck. Routed the cable under the hood for now and still need to sort out a good way to keep the parking brake from coming on without disconnecting cables on the rear calipers. I have some ideas, just need to test them out.
J
jfoj
Cleared trans codes with basic OBDII tool today. Too cold to fool around much for a few days. Next plan is to bypass auto Parking Brake engagement.
J
jfoj
Still trying to sort out using the transfer case Neutral function. While this is an option for the owners of 4 Wheel Drive vehicles, it initially appears it requires the engine to be running to use this feature, still trying different variations of what works and what does not work.
So my initial testing indicates that if you have a non running engine, you have no options for Neutral unless you manually override the parking pawl using the shaft on the side of the transmission.
This is why I purchased and permeantely installed the Park Release Tool, nothing more frustrating than not being able to put a vehicle in Neutral without too much effort safely. Still need to sort out a complete procedure for using the Park Release Tool because the Parking Brake get enabled if there is power available.
More to follow.
man n black
What does the manual say?
I ask bc when we were looking at 2023s one of the reasons we were looking is so that we could tow it behind our Motorcoach.
Manual at the time if I recall stated this was easily doable by placing the transfer case in neutral, so there must be some mechanism that allows for a neutral transfer case and no parking brake on 4wd models at least.
Since then, on our travels I've seen many 23+ half ton GM SUVs and trucks being flat towed behind coaches and RV's all over the South so it must be doable from the factory.
Ch
NipRing
