Map/dome lights on together
Cameron
Andalusia, Alabama
Does anyone know how to wire the map and dome lights together so they all come on when the doors open but still function properly with the switches
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you would need to install some specialized wiring of either dpst switches or rewire the the dome lights to branch off the bulb to the positive side of map lights. don't overload anything tho.
Cameron
Cameron
Andalusia, Alabama
I'm going to use 5smd LEDs so overloading shouldn't be a problem. If you just jumped the positive from the dome light to the map lights wouldn't it back feed to the dome light if you turned the map lights on separately
Cameron
Cameron
Andalusia, Alabama
Would you run a wire from the power on the dome light to the map lights in the whole truck and put individual diodes at each light
Bkerr82030
