Sound System silent when cold
29tomt
Have the same problem when its cold outside no sound! I pulled out the on star chime amp behind my head unit wiggled the wires and kept messing with it and the sound came on. Hoping this is the problem and I will update after a replacement is installed.
Did you find the problem? Tkx
nonickatall
Germany
I have sometimes as well the problem, when I start the truck that I have no sound at all. Radio is on, but there comes no sound. I switch of the truck, start it again and the sound is there.
That happened more in the winter, when the truck was cold, than now, so my suggestion is, that there is probably a small relay on the board of the amplifier, that stuck at this moment.
Does anyone know how the bose amplifier is switched on by the radio? Ot is it startet from ignition?
GuillermoDelTahoe
Another case here. It is all of my speakers ONLY WHEN COLD. I am sure of this.
One symptom I have is there is a faint (consistent) popping noise from the speakers.
If it was a single speaker connection it would only affect that one speaker. So must be something in or connected to the amp. The amp is so hard to reach I am reluctant to troubleshoot that. What would one do other than check/tighten wire harness connections? Cut back, and re-pin the harness terminal?
