Matching LEDs? Hi/Lo and Fog
gmtk
Going to replace both light housings on my 2011 SLT as they have condensation in them. Figured I would swap the bulbs at the same time. I’m impressed with the LEDs but can’t seem to find Hi/Los that will match a fog light combo. Found some that are close made by Cougar motors on Amazon but they aren’t exact. My OCD won’t let me install LEDs for hi/lo that don’t match the fog lights. Looking for suggestions. (Also debating just putting in silver stars and being done with it.)
01Konvict
Boats n Hoes
Raleigh/SML
Look at the retrofit source for LED options. The fogs are hard to find since its an odd bulb.
R Starr
My 2012 Tahoe has these LED's, All found on EBAY or WEBSITE DIRECT (I personally use ebay because of EBATES and PAYPAL)
These are all 6000K, Pure white daylight. Look fantastic!
Everything matches and they are all insane bright with an HID appearance.
Note: You will have to modify (drill out) some metal work behind the lamps for them to fit. No big deal.
2x LASFIT H11 H9 H8 LED Headlight Bulb Kit Low Beam Fog Light 60W 6000K 7600LM (LOW)
2x LASFIT 9005 HB3 LED Headlight Bulb Kit High Beam 7600LM 6000K White Light COB (HIGH)
2x LASFIT 5202 LED Fog Light Kit for Chevrolet Silverado 1500 2008-2015 6000K 72W (FOG)
2x JDM ASTAR 2x 50W 3156 3157 T25 6000K Super White LED Backup Reverse Light (DRL)
2x JDM ASTAR 50W High Power 3156 3157 LED Amber Yellow Turn Signal Light (FRONT TURN)
2X 50W 6OHM TURN SIGNAL LOAD RESISTORS + 4X WIRE CONNECTORS (FOR ABOVE FRONT TURN LED's TO PREVENT HYPERFLASH)
2x SYLVANIA ZEVO 194 LED Bulb Courtesy Side Marker Glove Box (FRONT SIDE MARKER)
Jhawk79
