Math Guru's needed!
Robert.K
San Diego, Ca
I just purchased a memphis audio Mojo 2500 amp. Want to know how much power I need to run it. all together my total system wattage is around 3000 watts. I know I need to upgrade stock alternator and also plan on running a extra battery(s) if needed. Any help would be appreciated.
Im using it to push a Memphis Mojo QVC 15( old style).
TnTahoe
TN
Ive been told to add up all the fuses that you have in all your amps and stuff and that should give you a rough estimate, but Im sure if you upgrade your alternator you would be ok, I cant see why your stock alternator cant handle one 15 though
WrenchGuy
WrenchGuy
Just divide by voltage. Considering you'll hold a 14.4 thats the highest you would pull.
Then it depends on the product you buy and wire you use. Efficiency.
Walkinblessin
