Maybe battery issue
dfib
I have an 08 yuklon xl. I have been experiencing what thought was something draining my battery for a couple of years where my battery dies in 1 to 2 days of not driving. It has been to the dealership multiple times and the battery an alternator have been tested multiple times. It always happens at home so I just hook up my charger until it starts. The battery can be so dead nothing works not even the remote. Lately it is get worse but today it was about 3 hours from when I parked it to when I had to go out again. this time the car barely started but it did and I wanted to try something, I shut it right off. Go to start it and it turns right over and it does this 4 times with the car starting fine every time. what can this be.
yates ™
Resident Apple hater
Iowa
You have something that is not shutting off with the key that is draining the battery. Do you have anything aftermarket on the Yukon?
D
dfib
just a radar detector that I can visually see shutoff when I turn the car off.
Forgot I had a rain bird for automatic wipers installed but the problem was happening before that.
Modded
That Guy
A radar detector does not shut off with the car when plugged in the cigarette lighter so I am guessing yours is hardwired?
Most drain are caused by some type of accessory. Do you have power steps?
Navigation system?
D
dfib
The radar is hardwired and I do have nav but no power steps
D
dfib
Just an update after multiple trips to the auto parts store and the dealership there was a short in the battery even though it tested good. Thanks for all your suggestions.
JoeR4065
