Misfire cylinder #4
YukonCO
I am new to the Kon and Hoe forum and have already gotten some great information. However, I have a problem with my 2000 Yukon (5.3) that I have not figured out. I get a Service engine light only when it idles longer than three minutes. After about 5 minutes it flashes. Stops flashing as soon as I drive it. I get the P0304 error (misfire #4). If i clear it and put a lever on the throttle to keep the idle at 1000 rpm - no error. Here is what I have done so far - changed plugs and wires - changed #4 coil - and changed the inline fuel filter and added B44 injector cleaner. What next before I take to a mechanic? Also, it fires immediately in the morning, but after driven and then shut off - it has to turn over for over 10 seconds before firing up again. Makes no sense to me.
BOSS
The People's A D M I N
Dallas
You're not getting a multiple cylinder misfire ??
B
92__silverado
Not to thread jack but when i start my hoe after sitting all night I get the flashing engine light also. I am hoping it is a plug/wire issue so i will be replacing those this week. If i shut it off and restart not issue.
2003 5.3 with 97k on the clock. Really hoping that its not the intake gasket.
SSmurdered
i know u see me
Pittsburgh, PA
i had a misfire on mine a while back. did plugs and wires and coil and didnt fix it. of course the last thing i tried was the fuel injector. no problems since
92__silverado
Did you clean the Fuel injectors or just replace it. I did a seafoam treatment in the gastank and of course that is when the problem started. But that is when it started getting really cold here too. Hard to tell. Hoping i just fouled the plugs but its odd that it goes away when i restart.
SSmurdered
i know u see me
Pittsburgh, PA
my CEL was on all the time and it was when it started to run ****** that i replaced the injector. i didnt try cleaning it first
04Hoe
Bad Fuel Injector, had the exact problem on my old Impala.
Y
YukonCO
I have gotten a Random/multiple misfire - but only once - the rest have been misfir cylinder #4
Max
Mile High
Denver
What brand of wire? Did the issue occur prior to the installation of the new wires or after?
BOSS
Dallas
Clear your codes, reseat the #4 injector harness. If you did all that as you said above, and are getting multiple misfire it could be clogged cats.
B
rmastro
