DallasTahoe
- Joined
- Aug 17, 2012
- Posts
- 711
- Reaction score
- 214
So I've been dealing with this all day, was goin down the freeway and heard some rattling, but it was the valves clattering, pulled over checked, nothing wrong then the ses light came on. Drove to autozone, I couldn't get above 1500 rpm because the valves will clatter real loud, so autozone pulled the codes, it was showing misfire cyl 4. So I replaced cap, rotor, wires, plugs, and coil, NOTHIN!! finally got it home, had to drive 40 miles @35 miles an hour. I stopped again at autozone just to see if any other codes came up, the p0304 code went away and it pulled p0300 instead. I pulled the plug on cylinder 4 and it was dry, then started it with the plug out and no gas came out and no change in how it was running so I'm pretty sure the spider injector is gone, right? I mean that's the only thing I can think of?? Help please!!!????
