I have a 2003 Tahoe with the 5.3 non flex fuel. It has almost 300k on it. I was getting a random misfire code on my obd. Happens after the truck is warmed up and usually happens at idle. Once it starts it may or may not happen while I'm driving. I took it in to a local reputable shop that specializes in electrical work. I also had 2 other unrelated issues** after several days of messing around with it they informed me the the truck needed and new PCM.
Shop findings:
Fuel injectors: good
Coil packs: good
Wires: good
Plugs: good
Misfire stayed on 3 and 7 after swapping injectors and they also replaced my fuel filter because it was partially clogged.
They wanted a good deal of money to replace and reprogram a PCM. I decided to do it myself. Bought one pre-programmed to my truck online and then installed. Did the key relearn and truck fired right up. Shortly there after the misfire returned. The connectors looked fine to my untrained eyes when installed the knew pcm. The only code I'm currently getting is misfire on cylinder 3 but I'll update with any additional codes if I see them. Let me know what other information I can provide.
**I also had an issue with a parasitic drain, pulsing interior lights, and and a throttle/pedal position sensor code occasionally putting the truck into low power mode, the shop did not seem to think the issues were related and blamed the instrument cluster for the parasitic drain**
Thanks in advanced for any help.
Sent from my SM-G950U using Tapatalk
Shop findings:
Coil packs: good
Wires: good
Plugs: good
