GrayKnight
- Joined
- Mar 20, 2012
- Posts
- 7
- Reaction score
- 1
I have a 1999 Yukon with a 5.7L V8, 230K miles on the odometer. It's been running fine, perhaps a little tired but still gets me down the road.
With winter coming on I decided to do some routine maintenance, including new AC-Delco plugs and wires. I carefully gapped the plugs to .060, as indicated on the decal in the engine compartment. (Out of curiosity, I checked the gaps on the plugs I took out and they were all at .062 or .063, so I'm pretty sure the gap isn't the issue.) After changing the plugs and wires, one at a time to make sure no wires got crossed, I started the engine expecting the same smooth idle as before the change. Instead, the engine ran rough. When I tried to drive it around the block the Check Engine light came on, and then started flashing. I made it back to the driveway and dumped the error code, which was P0300 indicating multiple cylinder misfires. I cleared the code, started the engine, waited until the Check Engine light came on again, and dumped the code. Same error.
I didn't do anything else except clean and recharge the K&N air filter.
Does anybody have any ideas as to what might have happened? I'm reasonably competent with mechanical issues but electrical stuff baffles me. Why would an engine that was running smoothly start missing in multiple cylinders after I installed new plugs and wires??? All suggestions gratefully appreciated.
