Mixing Tires
UpAndDown
Boston, MA (MetroWest)
I have an 08 Tahoe LT with about 125k in the clock. It’s a regular 4WD model, not a full time 4WD or full time AWD, but a regular selectable 4WD. I bought it recently and it needs front tires. The backs are still good for a while. It has Goodyear Wrangler SRA on it now. I found a pair of used Goodyear Wranglers with about the sam, maybe a little more, tread depth as the back 2 tires which I’d like to keep. What I am wondering is if it’s ok to use different tread patterns like this? The SRA has more of a ribbed 5 row design and the regular Wranglers have a more knobby 5 row type of design. The SRA are more of a highway all season type tire and the regular Wranglers are more of an all terrain type. They’re all the same size which is 275/55R20. Can I buy these and use them without any risk of harm when using Auto or regular 4WD Hi? Is there any other reason I shouldn’t buy them? Thanks for the help, I appreciate it.
97YukonNZ
Should be okay just as long as you have a matching pair front and have a matching pair rear,doesn't matter if a different pattern. I myself would put the knobbly ones on the rear where I am but it all depends on what suits your road conditions better.
Geotrash
Dave
Richmond, VA
I wouldn't use them with Auto 4WD, but should be fine as long as you're in 2WD and only use 4WD when the roads are slippery.
TollKeeper
Brighton, CO
Matching tires per axle, you are good with selectable 4x4. If it was AWD, that would be a different story.
Geotrash
Dave
Richmond, VA
Thanks TollKeeper. Any position including Auto or is that excluded? Opinions? Thanks again
Auto engages the collar in the front differential and that in turn will cause the front drive-shaft, output gear, and transfer case chain to turn, and the clutches will pre-load to a small percentage of their torque capacity. In other words, using mismatched tires in Auto mode will increase wear and tear.
U
UpAndDown
Very good info Dave. I appreciate it. Thanks very much.
jlmabiepsu
