MN8 : 4-speed HD Automatic Transmission- 4L85E Running Temps
MPDano
San Diego, CA
Hey all,
Got the full service for my transmission the other day. Full flush and filter and filled with Amsoil Signature Series Trans fluid.
I noticed driving to work, ambient temp around 65 degrees, the trans temp stayed around 160/165. I got to work around 25 miles away, ambient temp around 70, I see the temp staying around 185/190. Driving home it was close to 90 ambient, temp stayed around 185/190.
Is 185/190 a normal temp range unloaded? My engine thermostat is a 185. Engine always stayed nice and cool. Also, did the engine oil service as well. Royal Purple 5/30 and a new filter.
Still got the stock little trans oil cooler in it, which I will add another cooler in the near future.
Are my trans running temps ok unloaded?
Thanks,
Leo
MPDano
MPDano
San Diego, CA
Here are the running temps while I was in traffic going to work. Ambient temp outside was 86 degrees.
retiredsparky
100* above ambient temperature is very common. Tranny and fluid is fine up to 220-230*. The fluid flowing through the radiator from the tranny dumps excess heat, but will stay pretty close to that 100+ambient after warmup. Wheel bearings, differentials when not towing run about 50* above ambient temp.
MPDano
MPDano
San Diego, CA
Thanks for the reply. So I guess the real test is when i tow my Toy Hauler next week to the Desert.
MPDano
MPDano
San Diego, CA
Well, she did real good this weekend. The trans flush with Amsoil seemed to do the trick. I was hitting 240-250 on some of grades before the flush. This time around, i was full of toys, at least 1500 lbs heavier and never saw it get over 215 degrees.
Still gonna put the extra cooler for more transmission protection.
MPDano
MPDano
San Diego, CA
Installed the cooler in the rain. Fun. Started her up to temp and could feel the new cooler getting warm, so got good flow. Had to make a few dremel cuts on the grill as to not rub the cooler or hoses. Anyways, will report back on temps.
20170211_082813.jpg 20170211_082817.jpg 20170211_082820.jpg 20170211_082822.jpg 20170211_082829.jpg
MrBalll
West Texas
Nice looking install. Hopefully that new cooler will help you out more when towing that hauler.
kyle09
